Live Call Routing
Live Call Routing enables routing incoming calls and voicemails to on-call responders.
Live Call Routing enables end users and internal employees to dial a number and report incidents or leave voicemails for the issues they are experiencing. These calls or voicemails are routed directly to on-call engineers for prompt remediation of reported issues.
The direct channel established between end users and on-call engineers simplifies the process of reporting issues. Depending on the severity or frequency of reported issues, on-call engineers can triage and ensure quick resolutions, thus ensuring that the Mean Time to Resolve (MTTR) for customer-reported issues is always in check.
Prerequisites
Add a New Routing Number
To begin the setup process by adding an incoming Routing Number,
Navigate to the Live Call Routing page on the left navigation -> Add New Routing Number.
Enter the Name, and optional Description, and select an Owner for this number.
Select the Country for which you would like to have this number.
Select the type of number you want. The number can either be a Local number or a Toll-free number.
Then click Generate Number.
Select the behaviour of the routing number:
Play greeting and go to voicemail. Send the voicemail recording to the current on-call responder(s).
The caller can leave out a voicemail after selecting the affected service and the voicemail will then be attached to the incident created.
Play greeting and call the current on-call responder.
When the caller places the call and selects the service, Squadcast will route the call to the current on-call person(s) in the schedule attached to the Service. Once the on-call person picks up the call, the caller can report the issue to the on-call person.
When routing calls to on-call engineers, you can choose between two available strategies: Simultaneous - Calls all on-call responders at the same time. Each on-call responder receives a call and is prompted: “You have an incoming call from SolarWinds Incident Response. Press 1 to accept.” The first responder to press 1 gets connected to the caller. If no one answers or an on-call responder has voicemail enabled, the call will wait and ultimately go to the fallback voicemail. This strategy is useful when faster response times are critical. This is the default option. Sequential - Calls on-call responders one after another, in order. Each on-call responder receives a call and is prompted: “You have an incoming call from SolarWinds Incident Response. Press 1 to accept.” Once they press 1, they get connected to the caller. If the on-call responder does not answer or has voicemail enabled, the call will wait and then move on to the next on-call responder in the rotation. If no on-call responder answers, the call goes to the fallback voicemail. This option will help you for call rollovers when engineers do not respond in time.
Select the total duration of the call. The call will automatically disconnect after this specified time limit.
Craft your greeting message for callers in the text field. This message will be converted from text to speech and will be the first thing callers hear when they dial the number.
Structure the message to be read out during the call. This text will also be converted to speech and will play after each key press during the call.
Configure the Map Keypad:
For each key, a map
A Service
Provide an alias name for the selected Service
Attach Schedules
Click Save.
That’s it, now you have set up your Routing Number. We recommend testing this number out internally before putting it out for your end users to call.
Edit a Configured Routing Number
To edit a configuration for an existing Routing Number,
Navigate to the Live Call Routing page, hover over the desired configuration, and click Edit.
Make your changes and then click Save.
Delete a Routing Number
To delete a Routing Number,
Navigate to the Live Call Routing page, hover over the number you wish to remove, and click on the Delete option.
Confirm the deletion in the pop-up confirmation dialog to complete the process.
Sessions
In the Sessions section, you can view all the sessions associated with a routing number along with their respective details, as listed in the table below. To access this information for a specific routing number, simply open the Routing number details page and navigate to the Sessions section.
Caller ID
The number from the call is indicated.
Incident ID
The Incident ID of the incident created for the call.
Recording
The recording associated with the call.
Assigned To
To whom the incident got assigned to.
Selected Service
The selected service by the caller during the call.
Duration
Total duration of the call. From the user initiating it to the end.
To view further details about a session, hover on a session, click on View Session.
Here you can view the session details and to whom the call was routed to.
FAQs
Have any questions? Ask the community.
Last updated
Was this helpful?
